johnace25
What are the bases in dating
31 Mar 2026, 14:19
Hello, Guest!
Article about what are the bases in dating:
| Regain
What Are The &quot,Bases&quot, In A Relationship? When it comes to relationships, there is a lot of lingo that gets used. A lot of it is relatively recent &ndash, terms like cuffing and ghosting
>>> GO TO SITE <<<
When it comes to relationships, there is a lot of lingo that gets used. A lot of it is relatively recent &ndash, terms like cuffing and ghosting have only come about in the past few years. Some have been around a little longer, such as using the phrase &ldquo,bases&rdquo, to describe how far you have physically gone with someone. In the United States, mostly among American teenagers, baseball metaphors for your physical intimacy with someone and sex are often used as euphemisms. Bases is a term that, in its origins, has to do with, out of all things, the sport of baseball. While explaining the entire game and its nuances would take quite a while, all you need to know are the basics and where bases come into play. In baseball, the pitcher throws the player up at bat, who tries to hit the ball. Points are scored by making runs, and runs happen after running around three bases and returning home. How this analogy of bases and physical involvement with someone became intertwined is not quite certain. It dates back many decades, and along the line, it has also become murky in its definition. Here&rsquo,s a simple breakdown: First Base. The first base is the first stop on this physical relationship journey. It is the starting point: kissing. While this can encompass more mild kissing such as pecks, it generally means more meaningful kissing, such as French kissing or the term making out and open-mouthed kissing. Second Base. The second base gets a little bit more serious physically. Usually, it involves touching and is more intimate as to where that happens. The second base is touching about the waist. Areas such as the breasts and nipples are touched and fondled, especially below clothing. Third Base. The third base goes below the waist, entering new territory in that way. It involved touching or the oral stimulation of the genitals, including the penis, vagina, clitoris, and testicles. Oral sex, while it has the word sex and insinuates the &ldquo,final destination,&rdquo, is included as third base. This leads us to our final stop as we run around the field: Home Base (Occasionally Referred To As Fourth Base As Well) The home base is universal. No matter your definitions for the rest of the bases, the home base always means sexual intercourse. At this point, you and your partner have connected on an emotional level. Now, the two of you are ready to share a physically intimate moment. This moment should be treasured. You can express yourself clearly to someone else who is ready to accept you for who you are. So, respect your partner during your act of intimacy, as they deserve respect. Enthusiastic consent is always necessary, and consent can be withdrawn at any time by any person. First base, second base, third base, and a home run are your basic baseball euphemisms for sexual activity, intercourse, and everything leading up to. However, other terms are borrowed from the sport to describe other things within a relationship. Here are some of the other (perhaps not as well-known) terms: Strikeout. This one probably sounds familiar and is used quite often. In baseball, you get three attempts as the batter to hit the ball so that you can advance the game. Each missed swing is considered a strike. After three strikes, you are out, meaning your turn at bat is over, and the next batter is coming up to the plate. Perhaps you have heard the baseball song phrase: &ldquo,One, two, three strikes, you&rsquo,re out! At the old ballgame.&rdquo, This is what that refers to. Within the dating world, striking out works a little bit differently. While in both universes, it means you did not reach first base, in the dating world, it is not numbered. You could strike out endless times, or perhaps once. The &ldquo,three-strike&rdquo, rule does not apply, rather, striking out means you did not succeed with the person you wanted to be intimate with, and the first base was not reached. Remember that consent is always important and that while striking out has a negative connotation, if someone does not want to be intimate with you, you should respect their decision, respect their space, and move on. Unlike baseball, striking out is not negative in the dating and sexual world. It simply means that the person you were interested in is either not interested in you at all and does not want to pursue a physical relationship with you or does not want to be physical at that time. Even if you are physically involved with someone, there can be times when that person does not want to be physical for various reasons. They do not owe you the act of being physical, and it is important to get consent every single time to have a safe and happy sexual physical and sexual encounter. It is also important to be safe in your sexual encounters. In baseball, players not only wear a uniform but wear gear to protect themselves. The catcher&rsquo,s gloves help you catch the base, and the umpire wears protective gear so that the ball does not hit or hurt them. Be sure to be safe in your sexual encounters. Use protection and stay educated, tested, and informed so that nothing unwanted comes out of the situation. Sexual arousal is different for everyone. No matter what base you are on with your partner, it is important to keep the line of communication open to make sure you are both comfortable. People get aroused differently at each base, and talking to them during the process makes sure that everyone is on the same page. The bases, while they have been generally defined here, can also be different for everyone. Even other vague terms &ndash, such as hooking up &ndash, can mean something different between two people. For some, maybe it is only first base and making out. For others, it could mean sleeping with someone and hitting the home run. And yet, for others, it could mean anything in between. If you have a conversation with your partner, friends, or family, be sure to clear up what each base means. Some people may not want to talk outright about their sexual escapades. Having the baseball euphemisms as an outlet to slightly conceal what they are saying can make everyone more comfortable and conversation easier. Using these terms could be easier to connect with someone, especially if they are shy when discussing more intimate details of their lives. There are a few other terms that are still possibly thrown around regarding baseball and sexual euphemisms. They are a bit outdated but may still be heard from time to time, so we will talk about them here briefly. When heading to the ballpark, we have heard some of these other terms used as well: Grand Slam Or Pitching / Catching. A grand slam occurs when a home run is hit by the batter when all three bases are loaded or are already occupied with baserunners. This allows the team to score four full runs. Pitching is the act of throwing the ball while catching is the act of catching it. In the dating world, a grand slam refers to refer to having anal intercourse. This is a more outdated term and was used more when homosexuality was differentiated more than heterosexual sex. For this reason, this can also go under the first home run. Switch-Hitter Or Playing For Both Teams. A switch-hitter in baseball refers to someone who bats both right-handed and left-handed. To connect it to the dating world, a switch-hitter refers to those that are bisexual. The term came up because it was seen as &ldquo,batting&rdquo, for both teams &ndash, even though in baseball, a switch-hitter still only bats with one team, but with both hands. Someone can also use the term playing for both teams as well when it comes to bisexuality. Playing For The Other Team. Playing for the other team in baseball is a literal translation &ndash, you are playing for the other team. As you can probably surmise from explaining the &ldquo,playing for both teams&rdquo, euphemism, playing for the other teams refers to those who are gay or lesbian.
what are the different bases in dating
when dating what are the bases
what are the 4 bases of dating
what are the bases in american dating
