Elec_consum
Vendo Carrier Noise Test Set : Sunrise Telecom Sunset E10
21 Mar 2012, 00:17
Vendo equipo Carrier Noise Test Set : Sunrise Telecom Sunset E10 de segunda mano en muy buen estado.
HANDHELD TEST SET
Bit Error Rate with G.821, G.826 and M2100 measurements for nx64 kbps and 2.048 Mbps circuits. Also measures clock frequency, true instantaneous and cumulative clock slip and wander, as well as signal level and alarms simultaneously in two links.
Displays received signal pulse shape graphically, superimposed with ITU-T G.703 mask.
Measures BERT on leased datacom lines with G.703 co-dir, V.35, RS-232 etc. from 50 bps to 2.048 Mbps.
Measures VF level and frequency, Signal to Noise Ratio and Psophometric noise on any selected channel. Injects tone with variable level and frequency. Also allows a user to talk into any channel and listen to conversation bi-directionally while in-service.
Bi-directional MFR2C analysis and dialing with timed CAS (ABCD) bits transition and tonal event capture.
Detailed CCS7 protocol decode of CCS7 (ISUP, TUP, SCCP etc.), GSM (A, Abis.. at 16/64 Kbps).
Monitors GSM speech and C bits on 13 Kbps TRAU channel in uplink or downlink.
Dialing/call set up in MFR2C and ISDN
Fabricantes: Sunrise Telecom
Modelo: Sunset E10
Precio: 175€
