michaelhurst
[fortuna] Pokerstars 25 deposito bonus 2025
09 Abr 2026, 09:30
Hola, visitante!
Artículo:
We&#x27,ve put together a helpful article with all the info you need to know, so take a look! PokerStars Bonus Codes and Promotions 2025. PokerStars has one of the oldest promotions on the market, which has even served as a guide for new poker rooms to implement their welcome promotions.
Clicca qui per pokerstars 25 deposito bonus
Room Bonus Code Rakeback PokerStars 100% welcome bonus of up to $600 STARS600 30% PokerStars 100% welcome bonus of up to $100 + 100 free spins CASINO100 VIP. PokerStars. Independent. 100% up to $600. Japan is accepted. Manual to enter the bonus code at PokerStars. You must have a PokerStars account first. If you don't have one yet, the creation process is straightforward: You must manually type the Pokerstars bonus code when you deposit, depending on the promotion to which you want to apply (poker or casino): Click on the Cashier" button located in the upper right corner. Enter the amount of money to deposit and select the payment method. PokerStars welcome bonus: 100% up to $600. Claiming the PokerStars welcome bonus is very easy, and the code gives clues about the main benefit you will receive. By typing the bonus code "STARS600," the room will charge a locked bonus of 100% of your deposit up to $600. To release the bonus, you just need to play poker. You will be paid $5 into your Stars account for every 75 points you earn, and these are accumulated at a rate of 5 for every $1 of rake paid (regardless of the format). You can see the progress in the “My Rewards" menu, and you have four months to release the bonus. This bonus is usually accompanied by some free entry to famous tournaments such as the Sunday Million or satellites for it, these campaigns are usually random and vary over time. One of PokerStars' advantages is that you can make up to three deposits to reach a maximum of $600. Alternative bonus codes at PokerStars. In addition to the popular STARS600 code, PokerStars often offers reload bonuses with other temporary codes. If you live in a regulated country such as the United Kingdom, you may also need to use an alternative bonus code at PokerStars. The main alternative is the code CASINO100, designed for casino fans who prefer betting on slots or similar games and who take PokerStars as a one-stop betting site. If you use this code with your first deposit, you will receive extra money to play and 100 free spins. PokerStars UK welcome bonus. The United Kingdom receives a differentiated offer from PokerStars, although the British can access the global pool when registering. The code for the first deposit bonus in the UK is STARS400. You will receive a £400 bonus, which you will release at a rate of 6.5 points for every £1 paid in rake, and receive the equivalent of $5 for every 75 points accumulated. Bonus codes for other countries. As mentioned above, depending on your country of residence, you may have to use a different bonus code with your first deposit. The maximum bonus amount is usually changed, but the STARS are kept at the beginning. Country First Deposit Bonus Poker Bonus Code PokerStars Global (.com) 100% up to $600 STARS600 PokerStars United Kingdom 100% up to £400 STARS400 PokerStars Canada and Ontario 100% up to $600 STARS600 PokerStars Spain 100% up to €200 STARS200 PokerStars France 100% up to €100 STARS100 PokerStars Brazil 100% up to $600 STARS600.
