Hello, visitor!
Article:
8 Fixes! Is Find My Friends location not available on your iPhone? If so, take a look at this guide here, and we will help you learn how to fix Find My Friends location unavailable issue right away.
Click here for find my friends location online free
8 Solutions to Fix 'Find My Friends Location Not Available' There is no doubt that Find My Friends is an excellent application for location tracking. It allows users to track the location of their friends and family members through a variety of devices. So, when Find My Friends says the location is not available, it can be a frustrating situation. But don't stress over this because we are here to assist you in Find My Friends not working. Go through this guide, and you'll know what to do to take care of the problem. Part 1: What Does Location Not Available" Mean on Find My Friends? When the "Location Not Available" message appears on Find My Friends, it means that you have disabled location sharing or have turned off your device's location services. This message can also appear if your device is in an area with poor network coverage or if your device is turned off. In some cases, the message can indicate that you have logged out of your iCloud account or that there is an issue with the iCloud server. Does "Location Not Available" mean that there is something wrong with iPhone? Not! This message does not necessarily mean that you have blocked yourself or there is something wrong with your device. If you frequently see the "Location Not Available" message, you may need to check your own device's settings or contact your friends to confirm their location-sharing preferences. "No Location Found" means that the Find My app is unable to locate the device being tracked. This can happen for a variety of reasons, such as if the device is turned off, not connected to the internet, or if location services are disabled. "Location Not Available" means that the device is not currently sharing its location with the Find My app. This can happen if the device is in Airplane mode or if the user has turned off location sharing for the Find My app. It can also happen if there is a temporary issue with the iCloud servers. In summary, "No Location Found" means the app could not locate the device, while "Location Not Available" means that the device is not currently sharing its location. Part 2: Possible Reasons For Find My Friends Location iPhone Not Available: Why does Find My Friends say location not available? Before we get to the solutions, let's explore the possible reasons behind this problem. It is apparent that when the location is not found on Find My Friends, there is an underlying problem. Here are the possible reasons that could cause this error: Your friend's device has an inaccurate date The other device isn't connected to a network, or it's off Hide My Location feature is active on your friend's phone The Location Services are also turned off on the friend's device Your friend hasn't signed in to the service The location of your friend is in a country or region where Apple doesn't provide this feature. All these reasons can be the ones causing trouble on your iPhone and Android phones. Hence, you will have to look for some conventional methods to fix the unavailable location error. Part 3: 8 Tips To Make "Find My Friends Location" Available: When the Find My Friends app location is not available, here are some more tips that can help get rid of this issue. Tip 1: Check if Find My Friends is Supported in Region/Country: The foremost thing you should do when the Find My Friends location is not available is to check the region/country's location. Apple Inc still hasn't provided the Find My Friends feature in all countries and regions due to local laws and technical issues. So, the most plausible reason for the app not working properly is solely because it is not available in that particular country/region. Tip 2: Quit and enable GPS or Location Services again: After verifying that the feature is available in your region, enable the GPS & Location Services. In case you've already enabled the feature, turn it off, quit the app, and again enable the service. It might fix the location not found on the Find My Friends issue you've been facing. Just open Settings > Privacy & Security > Location Services and toggle the bar to turn the feature on or off. Tip 3: Adjust iPhone Date and Time: As we stated in the possible reasons, incorrect dates and times also result in this problem. If you have manually set the date and time, change the settings and set it to "Set Automatically" in General Settings. Hopefully, this will resolve the problem when the Find My Friends location is not available. Tip 4: Check the Internet: Before you conclude that there is something wrong with the Find My Friends app, check your internet connection. There is a chance that location is not available on the iPhone because your device doesn't have internet access. Try opening Settings > Mobile Data/Wi-Fi and turning it on and off. Alongside, make sure that you have signal strength, whether you are connecting to cellular data or a Wi-Fi network. Tip 5: Enable Share My Location: Another tip to try out when your friend's location is not available is to make certain that you've enabled Share My Location feature. To do this, follow the steps given below: Step 1: For iPhone users: get to the "Settings" app and go to "Privacy & Security". You will find the "Location Services" feature, click on it, and see the "Share My Location" feature. Toggle on the option to enable it. Once the feature is enabled, your friends will see your location, and you can see theirs. For Android users, go to "Settings" > "Additional settings" > "Privacy" > "Location", and choose the location mode to enable it. Tip 6: Restart the iPhone or Android Phones: The next tip to use when Find My Friends says location not available is restarting your phone. For most devices, the method is common. But for iPhone X and 11, the steps are slightly different. For other iPhone models, press the Power button and wait until the slider appears. For iPhone X and 11/12/13/14, you'll have to hold the Volume button and the Power button together to make the slider appear on the screen. Drag the Power slider to the right side and wait for the device to shut down. Wait for a minute before you restart the device, and hopefully, the feature will start working again as usual. Tip 7: Check That Your Friend Has Signed into Find My Friends: Another tip that can help you resolve to Find My Friends location not available is checking that your friend has signed into the app. It is apparent that if your friend hasn't logged into the feature, you won't access his/her location. Open the Find Friends app, log into it, and enable the location-sharing feature. Tip 8: Quit Find My Friends App and Open It Again: Last but not least valuable tip to use when the Find Friends location is not available is to quit the app. There is a possibility that you've faced the problem only because of a momentary issue or some random glitch. Make sure that you also clear the cache memory before opening the app again. It might fix the problem entirely. Extension: Can I send the fake location by Find Friends to others? With Dr. Fone - Virtual Location software, you will be able to share a fake or any location you want with your friends and family. Alongside this, Dr. Fone will also pace up your movement to ensure that your friends and family members won't find out that you share fake locations with them. The video below teaches you how to teleport your iPhone GPS location, and more tips and tricks can be found in the Wondershare Video Community.
how to find my friend location by mobile number free
