johnace25
Match making online free
26 Abr 2026, 21:01
Hello, Guest!
Article about match making online free:
What is Kundli Matching or Horoscope Matching? Kundli matching or Horoscope matching is the matching of one's horoscopes for marriage in Vedic astrology. When we talk about Hinduism and more importantly in context with India, marriages since centuries have been anointed with the blessings of the elders and parents.
>>> GO TO SITE <<<
So, matching Kundli has high-value significance when it comes to marriage. Marriages are often decided only after the Kundli Match or Horoscope Matching is done. When Kundli matching is done the exact position of the planets in one's Kundli is checked using an ancient system of calculations the precise position of different planet. For example, while looking at the position of the houses in once Kundli is done with the help of information like Name, place of birth, date and time of birth, which is then used to understand the position of planets in the different house in once Zodiac, it is also checked to understand which planets are lucky and more favourable and which planets have to be considered in case there is any kind of Dosha (when the planet is not in a favourable position) of it is known to what level the planets are blessing the bride and groom and which astrological rectification can bring happiness in marriage. Get Your Free Kundli Matching. Importance of Kundli Matching. When we talk about the importance of Kundli matching or Horoscope matching we need to understand the most important fact that Planets and celestial bodies have a great and linear influence on our lives, so whenever it comes to life’s most critical decision matching horoscopes for the future bride and groom are considered very significant as per Vedic astrology, and it is advised to get the horoscope matching done. The planets and the celestial bodies which are taken in account while doing a Kundli Matching or Kundli Milan are known to be the key players in our lives as they are the source of a lot of divine energy which can completely change one’s life. The position of certain planets in one’s birth magazine, when at a specific position and a certain degree brings amazing results and at the same time it can bring very unfortunate and inauspicious outcomes. This can be explained with the below excerpt from one of our posts on planet transitions, If we talk about the Planet transit Mars travels (Mars Transit) or does Gochar from one Zodiac to another in about 40-45 days. While Mars is transiting in the Capricorn Zodiac Mars is in the most preeminent state at twenty-eight degrees (28°), at this time Mars is known to be the most fruitful and gives its best results. On the other hand, Mars is at the lower house by twenty-eight degrees (28°) in the Cancer zodiac, during this time results can be quite painful for people with Cancer Zodiac”. Coming back to horoscope matching after knowing how the corresponding planet can affect two different zodiacs in a completely different way, we just need to understand that we live on a planet which is part of a planetary system and the movements of these planets affects our lives completely, however, the intensity of the same can be more or fewer factor elements for almost all the factor elements of our life which effects of so many things like marriage, the planet must bless itself so that there will be harmony, happiness, success and peace in the married life between the boy and the girl. A horoscope matching, little detail’s like the Names of the Boy and the Girl along with their Date of birth, Place of birth, Time of birth is taken into account. For the most accurate predictions, it is advised that one should carefully input or share the above-mentioned details astrologer or in case of any software or online application should input the details accurately. Why online Kundli Matching? You get the services at your own space, your own time, through your channel of communication. The reports can be sent to you by email or by post. While physical Kundli is a good option for record-keeping however online portal gives you access to your Kundli 24/7 at the comfort of your screen size and is accessible whenever needed. In case if you are also looking to find your horoscope readings then do not wait longer and connect with our expert Vedic astrologers. We have dedicated team of expert astrologers who will analysis and get reports based on your horoscope readings. To get in-depth information about your horoscopes then wait no longer and get your horoscope reports today. For more details connect with our expert astrologers today. Kundli Matching for Marriage. The prime objective of Kundli match making is Attribute matching (Gun Milan) chiefly. Majorly eight sorts of characteristics and Ashtakutas are considered while matching the Kundli qualities is very essential in marriage. These characteristics are Varna, Vasya, Tara, Yoni, GrihaMaitri, Gana, Bhakuta and Nadi. There is a total of 36 digits after matching them all. At the time of marriage, if 18 qualities out of 36 are found in the horoscope of both the bride and groom, then it is believed that the marriage will be successful. These 18 qualities are related to Health, Dosha, Financial state, Mental state, Child etc. Let us tell you that according to astrology, how many qualities are good for marriage and how would be the final results inauspicious. In case you are looking forward to getting your horoscope reading then use the below form and order to get a horoscope report specially designed for you. What is Gun Milan and explanation? Gun Milan in a Kundli (Birth Chart) works property matching the same is done in the case of, and, in the same way, as in the case of a person. The pulse code (Naade Koot) is given the much eminent superiority in matching the characteristics of the horoscope.
